Repair and disassembly guides for Epson printer. The company was founded in 1942 as Daiwa Kogyo, Ltd., but merged with another company in 1959 to create Suwa Seikosha Co., Ltd.
new printhead and ink cartridges in my Epson 7800 won't print
I have a new printhead and new ink cartridges in my Epson stylus pro 7800. No error messages at startup. I have run power cleans with negative results, test prints and printhead alignments with negative results or error messages as well. I am able to manually pull in through the dampers and lines with a syringe. The printer runs smoothly, sounds normal and appears to function as normal but there is no ink visually running through the lines. and nothing being transferred to the paper. Please help.
Hey John,
Since you’ve manually pulled ink but the printer won’t, here are some things to check:
  • Air in Ink Lines – Even small air bubbles can block flow. Try priming again.
  • Dampers & Seals – If clogged or leaking, they’ll stop ink from reaching the printhead.
  • Capping Station & Pump – If these are faulty, the printer won’t pull ink properly.
  • Firmware & Software – Make sure everything is up to date to rule out glitches.
If nothing works, a technician might be needed. Hope this helps!
John Fuscellaro crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 38
