Turns on but there's no picture
Goin by the only info youve given it sounds like either youve got it on the wrong signal source, backlights have went out or the power board for some reason is t sending power to the lights!
@adahart you have not told us what you have checked. The no video issue can be related to a bad backlight inverter circuitry or a bad backlight array. A simple check for that would be to darken the room and turn the TV on. If it remains dark, turn the TV to a channel where you can hear the sound. Next, use a flashlight and shine the beam at an angle against the screen. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed.
If you do not see anything, unplug your set and remove the back cover. Then visually check the boards for any obvious damaged components. Check all the wiring and unplug the wires and plug them back in, make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board or a T-con board issue.
crwdns2942667:0crwdne2942667:0 279
Hi @adahart
Please confirm the model number of the TV?
Can you hear audio when the TV is on with no picture?
What is the signal source for the TV e.g. antenna, pvr, streaming device etc?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
can you see the TV menu you may have not set up correct. or the screen light is out.
crwdns2934271:0crwdnd2934271:0 om1gc crwdne2934271:0
No cant see anything but there sound the tv is hisense led lcd tv ,model #75h65706
crwdns2934271:0crwdnd2934271:0 Adam Hart crwdne2934271:0
