LG WM2250CW cold water won't stop filling.
Our LG WM2250CW washer has an issue where when we use any cycle that uses the cold water the cold water will keep filling, usually filling up to over halfway up the door. Sometimes it will cause an FE error, but sometimes it ends up skipping time in the wash cycle and moving on to the rinse cycle. The rinse and spin cycle will also keep filing with cold water at the same time it is trying to drain out. It will do this for awhile in the spin cycle until the cold water finally shuts off. We have had a couple times when the water would not shut off even if we paused the cycle or turned the power off, we had to shut the water off at the supply. When we run a purely hot water cycle the hot water seems to cycle correctly, but when it gets to the rinse and spin it will again keep filling cold water at the same time it is draining for an extended time. The FE error led me to replace the fill level pressure switch, which did not fix anything. I have also cleaned the water inlet screens and checked those valves for continuity and they seem fine. Does this seem like a control board issue? It seems like it can control the cold water inlet valves but it is not shutting them off correctly. Thanks for the help.
this is the key "We have had a couple times when the water would not shut off even if we paused the cycle or turned the power off,"
If the water keeps running with no power then the water valve is stuck open. Replace the water valve.
Hi @chrisb38144
Here's the service manual for the washer.
Go to p.14 to view the procedure for how to get into the QC Test mode, so that you can check if the main wash valve (cold water) is working OK or not and if any other error code is being displayed.
I have an LG Washer Model #WT1101CW with the same issue. Cold water kept running even after powering off. My issue was NOT the water inlet valve. First I replaced the valve because it looked rusty so I figured that was the problem. No luck, the water still poured out. Then I replaced the main control board and that solved the problem. The board controls the inlet valves. Cost me $100 off Ebay. Cheaper than buying a new washer! Part # LG EBR76262102
Chris B crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 33
crwdns2942667:0crwdne2942667:0 123
