Nintendo Game Boy Advance, released in 2001. Repair requires only common tools and no heat.
Gameboy Advance - doesn't turn ON (ON/OFF switch cleaned)
Hi guys!
I have this old GBA which doesn't work and I decided to try to repair it. There was battery leak inside and the power button was damaged. At first the gameboy didn't turn at all. I disassembled it, opened the power switch, cleaned it up and I now it's still not working (haha) but there is som led blinking for a while and just a milisecond buzzing sound from the speaker.
I have also tried to jump the switch ON pins with a wire to bypass the switch but the result was the same.
I have also checked continuity from + -> F1 -> 101 -> Q5
No screen at all...could you please help me what should I try next?
Hi there!
The only advise I can give you is to replace the ON/OFF power switch.
If this didn't worked, please check the traces there. It's possible that the traces and/or the solder pads are damaged and causing this.
As far as I can see, this is related to the power switch or it's traces or solder pads...
wiston crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 244
