My DJI mini 2 controller won't charge
My DJI mini 2 controller will not charge
If your DJI Mini 2 controller isn't charging, first check that you're using the correct charging cable and power source, then try using a different cable and charger to see if the issue persists; if it does, the problem might be with the controller itself and you should contact DJI support to potentially send it in for repair.
crwdns2936753:030crwdne2936753:0 8
crwdns2942667:0crwdne2942667:0 40
