Huawei p smart 2019 Replaced Lcd screen now getting horizontal lines
Phone doesn't work anymore without being plugged in
It powered off and I thought a simple restart would help but it didn't so I factory reset it but still the issue persisted. I even replaced the battery but still the same issue
Hi Fred,
Your instincts were good on this one; replacing the battery is where I would have started too. However, given that didn't help, let's see if we can puzzle out your next step.
If the phone powers on only with the charging cord but the battery is new, then I would suspect something in the charging circuit. That's usually a function of the motherboard on most phones, but yours has a daughter card that holds the charging circuitry and the USB-C port. I would look at that as the next suspect; in addition there's a flex cable connecting that daughter card to the motherboard that could be a possibility, but I'd personally try the daughter card next.
Sorry to say iFixit doesn't have a guide to that repair for you, but there's a Spanish site that has just what you need. It is, of course, written in Spanish, but if you use the Chrome browser's translation feature, it is quite easy to use and well done.
Manuales / Huawei P Smart (2019) / Auxiliary plate - Nadie Me Llama Gallina
i had a vivo v17 pro and it had the same problem. its probably because your battery is not properly working anymore. you can go to a mobile repair shop and he will fix your battery or put a different one in it.
If you read the original post more carefully, you'll find that Fred has already replaced the battery and it didn't help.
Fred crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 247
