he Xiaomi Redmi 8 is a low-budget smartphone by Xiaomi released October 2019. It has a 6.22" IPS LCD display, a 12 MP main camera, a rear-mounted fingerprint sensor, a 5000 mAh battery, and runs on a Snapdragon 439.
My cellphone is completely dead and won't turn on.
My cellphone suddenly turned off, when I tried to turn it on again the screen suddenly turned blue and then it couldn't be turned on again.
crwdns2944067:05crwdne2944067:0
When I try to turn on they did not respond
@laxmiagrawal proceed the same way as outlined in my original answer
Mere phone me Pani ghuss gaya hai
My phone not start
@shadanansa76789 Try everything suggested by @oldturkey03 in his answer then come back and let us know what you found.
@arulselatan TRy a hard reset by fiollowing the insructions on here. Or you can try to get in Fastboot Mode by pressing the vol -and the power button at the same time and keep both buttons pressed. It is possible that you have a corrupted OS.
If none of that works consider this a hardware issue. First replace the battery. Then check the charging board and the ribbon cable going from the charging board to the main board. Make sure that it is properly seated and shows no rips, tears etc. If a new charging board and a new battery does not resolve this, the issue will be on your circuit board. For that you do need to have the schematic as well as the boardview and the knowledge to perform boardlevel troubleshooting. Most common would be failed flash memory.
Since iFixit does not yet have a specific guide for this, use something like this video
arul selatan crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 70
crwdns2942667:0crwdne2942667:0 551
