The OnePlus 12 is an Android smartphone from OnePlus. It was released on December 5th, 2023 in the Chinese market then released worldwide on February 5th, 2024.
Power putton is nearly stuck and doesn't work 9/10 times
There is a simple guide to open the oneplus 12 5g to reach the power button and check what keep it nearly stuck?
It is not totally stuck, I think it is something mechanical not working.
Hi,
The buttons on a phone are designed to move in and out freely, if you check the operation of the other buttons you should see how the power is meant to feel.
If your power button doesn’t have the same easy movement then it’s possible that you have a buildup of dirt and/or grime that is reducing the buttons ability to return properly.
You can try using some 98% isopropyl alcohol and a soft brush to try and clean in between the button edges to see if this helps.
If that doesn’t work then it’s possible that the contact plate on the inside has been bent back from the button being pushed too hard, too long.
In this case you may need to open the device, inspect the contact plate and replace if necessary.
You can find guides on how to replace buttons for your device on YouTube.
Hope this helps
Raikoug Bolt crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 35
crwdns2942667:0crwdne2942667:0 823
