Apple's top-of-the-line smartphone for 2020. Announced on October 13th and released November 13th, the iPhone 12 Pro Max sports a 6.7" OLED display, a triple rear camera system with LiDAR, and 5G connectivity. Successor to the iPhone 11 Pro Max.
Says cellular is unavailable and my friends phone won't update
My friends phone got ran over by a car and the screen is destroyed but it's fixed but says cellular needs an update and when try to update it gets stuck on verifying update. I really wanna get the cellular working.
Have you tried to update with iTunes with a cable connected to the computer?
Hi,
Based on the information you provided, you will need professional help to fix your iPhone 12 Pro Max. The motherboard is affected by physical damage. (this is not a software problem)
iPhone 12 Pro Max has a sandwich motherboard. The top board is responsible for UI, and the bottom board is for communications. If the top board does not detect the bottom board, your iPhone will report a cellular error. The top and bottom boards are joined together with a connecting layer. As the iPhone was run over by a car, most likely, the connections are broken/disconnected.
To confirm this problem, go to settings/general/about and check Wi-Fi, Bluetooth ID, and Modem firmware. If any of these are missing, then it's a hardware problem.
BR
Francis
CelMetro
ATVB1 crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 68
