Repair guides and information for the HP 250 G3, a budget laptop released by HP in 2014.
Not connecting pawer & up coming
পাওয়ার আসছে না, কি বোর্ড এসে চলে যাচ্ছে।
Translation Bengali - English
Power is not coming, what board is coming and going.
@muhammadta76511 you are not giving us a lot of information. We would at least need to know what you have checked and if your laptop shows any sign of life.
Translation
@muhammadta76511 আপনি আমাদের অনেক তথ্য দিচ্ছেন না। আপনি কি পরীক্ষা করেছেন এবং আপনার ল্যাপটপ জীবনের কোন চিহ্ন দেখায় কিনা তা আমাদের অন্তত জানা দরকার।
@muhammadta76511 you are not being very specific with your information. Here is a general answer on how to troubleshoot your computer issues. Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
First you want to check your power supply. Make sure it has the proper voltages. Check to make sure that connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see. Adding images to an existing question
Of course, you may also have to consider replacing the battery. A depleted battery can no longer be charged. However, it should not prevent your computer from coming on, if it is connected to the AC adapter.
Of course, it is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
To work on your computer use the HP 250 G3 Maintenance And Service Guide Sorry, I an only find the English version. You may have to use one of the many free PDF online translators to make it work for you.
Translation
@muhammadta76511 আপনি আপনার তথ্যের সাথে খুব নির্দিষ্ট হচ্ছেন না। আপনার কম্পিউটারের সমস্যাগুলি কীভাবে সমাধান করবেন সে সম্পর্কে এখানে একটি সাধারণ উত্তর রয়েছে। সহজ জিনিস দিয়ে শুরু করুন। আপনার কম্পিউটার থেকে পাওয়ার কর্ডটি আনপ্লাগ করে কম্পিউটার থেকে পাওয়ার সংযোগ বিচ্ছিন্ন করুন। কম্পিউটার থেকে সমস্ত বাহ্যিক ডিভাইস সংযোগ বিচ্ছিন্ন করুন। ব্যাটারি সরান এখন পাওয়ার বোতামটি প্রায় 30sec-1min ধরে ধরে রাখুন। এসি পাওয়ার অ্যাডাপ্টারটি পুনরায় প্রয়োগ করুন এবং দেখুন আপনার কম্পিউটার জীবনের কোন চিহ্ন দেখায় কিনা।
প্রথমে আপনি আপনার পাওয়ার সাপ্লাই চেক করতে চান। এটি সঠিক ভোল্টেজ আছে নিশ্চিত করুন. কানেক্টরগুলি বাঁকানো ইত্যাদি নিশ্চিত করতে পরীক্ষা করুন৷ আপনার ল্যাপটপের ডিসি-ইন জ্যাকটি পরীক্ষা করুন৷ নিশ্চিত করুন যে কোনও ক্ষয়, ধ্বংসাবশেষ ইত্যাদি নেই যা এটিকে কাজ করতে বাধা দেয়। কোন ধ্বংসাবশেষ ইত্যাদি থেকে এটি পরিষ্কার করুন, এটি পরিষ্কার করতে কয়েক পাফ বাতাস ব্যবহার করুন। যদি এর কোনোটিই কাজ না করে, তাহলে একটি অ্যামিটার পান এবং দেখুন আপনার ল্যাপটপ চার্জার থেকে কোনো অ্যাম্পেরেজ ড্র ​​করে কিনা। এর পরে, আপনাকে পরীক্ষা করে দেখতে হবে যে আপনার মাদারবোর্ড এমনকি পাওয়ার পায় কিনা। এর জন্য অবশ্যই, আপনাকে এটি খুলতে হবে। আপনি কি দেখতে কিছু ভাল ছবি পোস্ট. এইভাবে আপনি যা দেখছেন তা আমরা দেখতে পারি। Adding images to an existing question
অবশ্যই, আপনাকে ব্যাটারি প্রতিস্থাপনের কথাও বিবেচনা করতে হতে পারে। একটি ক্ষয়প্রাপ্ত ব্যাটারি আর চার্জ করা যাবে না। যাইহোক, এটি আপনার কম্পিউটারকে আসতে বাধা দেবে না, যদি এটি AC অ্যাডাপ্টারের সাথে সংযুক্ত থাকে।
অবশ্যই, এটাও সম্ভব যে এটি একটি খারাপ RAM মডিউল বা একটি খারাপ LCD। তাই RAM মুছে ফেলুন, একটি পেন্সিল ইরেজার দিয়ে পরিচিতিগুলি পরিষ্কার করুন। এটি মৃদু করুন যাতে মডিউলটি ধ্বংস না হয়। এটি প্রতিস্থাপন করুন এবং পুনরায় চালু করুন। আপনার যদি একাধিক মডিউল থাকে তবে এটি সরান এবং শুধুমাত্র একটি সংযুক্ত রেখে দিন।
আপনার কম্পিউটারে কাজ করার জন্য [ডকুমেন্ট|39115] ব্যবহার করুন দুঃখিত, আমি শুধুমাত্র ইংরেজি সংস্করণ খুঁজে পাই। এটি আপনার জন্য কাজ করার জন্য আপনাকে অনেকগুলি বিনামূল্যের PDF অনলাইন অনুবাদকের মধ্যে একটি ব্যবহার করতে হতে পারে৷
MUHAMMAD TAREKUL ISLAM crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 45
