Why my phone doesn't charge
My tecno pop3 is not charging
@ronny22166 first check your charger. Make sure it has proper output. Then check your charging cable. Check to make sure connectors are not bend etc. After that, check the charging port. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get a USB ammeter and see if your phone draws any amperage from the charger. If it does not it is possible that this is a charging port issue or a bad battery.
To check the charging port, use a voltmeter and measure the voltage on your battery connector. Next plug your phone charger in. Now measure the voltage on your battery connector. That voltage will have to have increased. IF not then the issue is either the charging port or the charging circuit.
Since iFixit does not yet have a guide for this phone, Use something like this video right up to 2:15min. Personally , I would replace the battery and the charging board.
While you work on your phone, take lots of pictures. Once you are done with it, take those pictures and create a guide for iFixit. That will help the next person that has a device with the same issues as you do. It's easy and fun to create these guides. https://ifixit.com/Guide/new The iFixit community will appreciate this.
Repair is War on Entropy!
crwdns2942667:0crwdne2942667:0 134
Pop2 battery connector
crwdns2934271:0crwdnd2934271:0 Ahmeddin Ame crwdne2934271:0
@ahmeddiname try to expand on your question. We do not know what it is that you are asking about the battery connector.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
