Is my phone's charging system working?
Hi, so I dropped my samsung phone into the sea in winter and I left it on my drawer for months. Now I tried to fix it, took off the motherboard shields and cleaned the corrosion. After that I replaced the charging board. Now I measured the end of the main flex and it shows 5v. When I measure the battery connector it shows 2.1volts. Is this normal? Should I pay 70 dollars to replace the screen and battery or is it a waste? Please answer, it is a very important phone to me, thank you
Update (07/05/24)
@oldturkey03 I cleaned all corrosion tho, even under the sheilds... Could it indicate anything else? Also now that I am checking with my multimeter I check 2.4 volts at the battery connector while charging instead of 2.1 volts. Also heres a photo of the motherboard
Also I got the ammeter, it shows 5volts and 0.00 amps. What should I do? My new battery also reads 2.65 volts with the multimeter, is it normal?
@oldturkey03 here you go:
crwdns2944067:04crwdne2944067:0
@theelectro54594 what does the underside of the board look like?
Perfect. Thank you. Looks like you have some trouble with the EMI shields. Hard to see even when zoomed in but you do not see any damaged traces? (last picture bottom right)
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
@oldturkey03 I don't think they are damaged... I tries to pry them up with a screwdriver and without any heat, big mistake. But why does my ammeter show 0.00 amps? Why is my new battery 2.65 volts? Is it bad? What is the chip responsible for power management and charging and how do I check them?
crwdns2934271:0crwdnd2934271:0 TheElectronicsFixer crwdne2934271:0
@theelectro54594 that means your phone is not pulling any amps from your charger. which is bad. That means you are having a shorted charging circuit. Let me see if I find the PMIC for the charging logic
@oldturkey03 So.... are there any news? What should I do about the 0.00 amps? Should I replace my new battery again which is 2.65 volts? I need some further instructions. Thank you
