The HP ProDesk 400 G3 is a business-orientated desktop computer released in Q4 of 2015.
Can't setup a windows on my ssd
can't setup a windows on my ssd or games it gives me an error and its speed stuck sometimes
crwdns2944067:010crwdne2944067:0:
What is the system you are trying to connect the SSD to? Make, model and the interface.
@danj win10 and it is sandisk
@ziadsayed - I got the Windows OS part but what is the hardware? Dell, HP or Home Brewed then the logic board… and what is the exact model? And which SanDisk drive as the interface it uses is what we need to know.
hp,
sandisk x400
@ziadsayed - I guess we are pulling teeth 🦷 Ok still not enough!
Think it this way… I have a Ford 🚘 what headlamp does it take? There are over 20 just for the car! So as you can see one needs to narrow things down.
OK - We have a HP but which Model an old Core2Duo or something newer what is the Interface you are try to use the SanDisk x400 comes in a few different formats! A SATA or M.2 mSATA 2280 form factor.
I get it such an easy question! Why do we need to know this stuff!
Well… without knowing it will be impossible for someone on the other side of the world to help you. Sorry you are my eyes I can’t see what you have here.
crwdns2934275:05crwdne2934275:0
@ziadsayed good. Now use the HP ProDesk 400 G3 MT Maintenance And Service Manual to check where the SSD connects to. The SanDisk X400 is a M.2 2280 SATA III (6 Gb/s) backward compatible to SATA II and I. It should work in your computer without any issues. You need to let us know what error you get when you try to install Win10 to it. You have to make sure that your computer truly is a MT since officially only that supports M.2 SSD's drives.
Take a screenshot of the Disk Manager and let us see what your computer sees. I wonder if you installed the OS to the SSD in Legacy mode instead of UEFI mode. Double check that.
Adding images to an existing question
Ziad Sayed crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 182
