Why won't my laptop turn on after pressing the power button
After pressing the power button, it won't turn on and the charging indicator turns on when the laptop is plugged to a power source
Here is one possible route to follow:
HP Laptop BIOS Recovery Win and B or V Key
  • Check Key Combination: First, make sure you are pressing the correct key combination. On some HP laptops, the key combination for BIOS recovery might be different. It's usually "Windows + B" or "Windows + V," but it could vary. Check your laptop's manual or HP's official support documentation for the correct key combination.
  • Power Cycle: Turn off your laptop completely and unplug it from any power source. Then, press and hold the key combination ("Windows + B" or "Windows + V") and while holding it down, press the power button. Keep holding the key combination until the laptop's screen lights up or you see any signs of BIOS recovery.
  • Use a USB Drive: If the key combination method isn't working, you might need to use a USB drive with a specific BIOS recovery file. Visit HP's official support website, enter your laptop's model number, and look for the BIOS recovery files and instructions for your specific model.
Another:
Shut down. Disconnect charger, open case and disconnect the battery. Press and hold power button for 30 seconds.
Now some just reconnect the battery and try the power button. I prefer to first plug in the charger to see if it works. If yes then you know the charger works and the battery may be defective causing a short. Then disconnect the charger and reconnect the battery. If it works the BIOS was probably corrupted somewhere. If not replace your battery.
Anthony Kariuki crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 43
crwdns2942667:0crwdne2942667:0 319
