When u turn the key it doesnt crank over?? Does nothing? If you can get to the solenoid, maybe u could turn key to run position not start, take screwdriver and arc from Positive battery cable connection to solenoid to test if starter engages it may run with key on. Then u know problem is between key switch and starter. If the key wont engage starter but u can arc it and it engages. Prolly ign. switch not key switch faulty. Or neutral saftey switch, fuse, relay, wiring issue, security pass lock. Need more info on car stopping cranking all of a sudden. It cranks but wont start/run?. Or doesnt crank? When u turn the key?
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
