Hey Doug,
The panel touch panel on the microwave is easy to diagnose, if you pop the front panel at the top off and then remove the touch panel assembly you will see a ribbon cable that runs from the keypad and is placed into a board connector. In the past I have simply removed the ribbon cable cleaned the copper ends with alcohol and a paper towel placed it back in the connector and the problem resolved.
Make sure you unplug the device before attempting to service it, There should be a little clip on the ribbon cable connector that you flip up to remove the cable. clean it then make sure you place the cable back in fully seated and clip it back. Reassemble and test.
While you have it open on the front if you notice anything else post me a picture.
Cheers,
Monte
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
