Can't regulate heat
Cannot regulate the heat
Update (11/23/23)
Whirlpool Model ACE244XSO The heat will vary 10+ degrees------ up and down without moving the thermostat setting. Probably the thermostat but I haven't found one for it.
Hi @calvinwiles,
What is the make and model number of the Air Con unit?
Hi @calvinwiles
There are two thermostats in the air con unit, Item #10 and #31 airflow and control parts diagram
Temperature control thermostat Item #10 is part # WP1185753 (supplier examples only).
Item #31 is part # 4388458 but I can't find any online. This one looks more like a safety cutout thermostat for the heater given its location, rather than a room temp control thermostat like Item #10. If you suspect it is the problem, check if there's a different part number on it or a make and model number and search online using that information
crwdns2886500:0Regulates temperature within your appliance to maintain consistent performance.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
Whirlpool Thermostat - WP1185753
$132.99
Calvin Wiles crwdns2934231:0crwdne2934231:0
crwdns2959996:0crwdne2959996:0 300
