The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
Switch Won't Turn On (Unpatched V1)
I'll get the unpatched part out of the way first. The serial starts with XAJ7003 which I believe is unpatched hardware that can be more easily modded. I don't intend to do this but it may be that the previous owner tried and bricked the console.
I bought a used "junk" switch from Japan and it failed test #1 - it doesn't turn on. No charging/battery icon and no signs of life. I did a bunch of tests listed below, and any parts or tools used are verified working from my store bought and still working fine Switch.
  1. Plug it in to charge for a few hours (official Switch charger to wall and USB to PC)
  2. Use a fully charged battery from a working Switch
  3. Hold the power button for 20s and then press again
  4. Open up and clean all ribbon cables and re-apply thermal paste
  5. Try to power on while docked in case the screen wasn't working
  6. Press the power button directly on the board/ribbon
  7. Test continuity on various things with multimeter (I don't really know what I'm doing here but everything I tested had continuity)
If I plug it into my computer it's listed in Device Manager as APX (!). Not sure if that means anything.
The internals were all very clean and beautiful other than a tiny bit of dust, which hopefully suggests nobody has opened it up to tinker before me.
I'm hoping someone could give me advice on what to try next.
Me and u gang me and u😔
@jamaalkay check if its in rcm by downloading the software in the link i provided and connect the switch to the pc
download tegrarcm from here https://github.com/eliboa/TegraRcmGUI/re..., connect the switch to the pc to see if it shows that its in rcm mode
No luck. Windows plays the device detected sound but TegraRcmGUI says "No RCM device detected".
However, after having it charge for a bit I did notice there's a warm spot on the top of the device between the volume buttons and the exhaust.
@fliggle_slaps if windows makes the connected sound then its possibly switched on. can you take the back casing and metal shield off
Fliggle_Slaps crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 170
