Casio's scientific calculator released in June 2015. Uses Classwiz technology and is widely used in exams.
Calculator is in 'PAUSE' mode
The calculation was done in VECTOR mode from the menu. When trying to do something, the calculator hangs, after clearing by the 'ON' button, you can see this status of MENU. Apart from these 3 modes, no other mode is showing, if I want to scroll up or down, the pause sign (2nd picture) is coming on the upper right side.
⁉️ How to get back all mods like before?
According to the manual, page 2, you can initialize (aka reset) the calculator by SHIFT 9 (RESET) 3 (Initialize All) = (Yes)
Note: this is a duplicate as the answer with the link was marked as spam
By the way, @nayemmonir , here you can find the manual
Here’s a quick fix for your calculator:
  1. Press SHIFT + 9, then press 3 to initialize everything.
  2. Next, press SHIFT + 7 + ON. The screen will display "DIAGNOSTIC."
  3. Avoid pressing AC. Instead, press 9.
  4. The screen will fill with 8's. At this point, press SHIFT, then ON.
Your calculator should return to normal! Hope this helps!
According to the calculator manual (see page 2), you can initialize/reset the calculator by pressing SHIFT 9 (RESET) 3 (INITIALIZE ALL) = (YES)
doesn't work this
@nayemmonir Have you tried removing the battery as @dannish said?
yeah, nothing changes
@nayemmonir Ok, anyway that symbol means "The display currently shows an intermediate result of a multi-statement calculation." (page 4 of the manual, can't link due to antispam). Maybe is still waiting for input?
@nayemmonir Have you tried removing the battery for a few minutes? That may reset the calculator to default settings.
I just did but it doesn’t work 🥲
Nayem Monir crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 51
crwdns2942667:0crwdne2942667:0 595
