Dell Inspiron 17r is making a clicking noise and won't boot.
I've found a solution to this problem and figure I'd post here so it may help others. A client handed me a Dell Inspiron 17r which was not booting properly. When the power button was pushed, it started a strange "clicking/beeping" noise, about every 2 seconds. This noise was not from the hard drive, but rather was coming out of the speakers. After multiple attempts the laptop would boot, but the problem continued next time the machine was shut down and restarted.
I rebooted into the Dell Diagnostics and did a full scan of the machine. All tests passed. An Internet search, and search on the Dell site didn't reveal any solution. I went on the Dell support site and found that there was a BIOS update for the machine. It was running A08 I think, and the update was A16. I downloaded and tried to install, but the install failed multiple times as the BIOS update requires a reboot of the machine to install, and it was suffering the boot/clicking problem so the BIOS update was failing. I'm stubborn and persevered, and attempted the BIOS update maybe 20 times or so, then finally once, the machine booted properly and the BIOS update installed. Problem gone after that. I truly believe Dell has a known issue with these and similar model laptops but have not admitted it. There is no "quick" repair to update the BIOS if the machine won't boot properly to install the BIOS update. You just have to be persistent and stubborn and keep trying; hopefully you can get it to boot once properly and get the update installed
Thanks for that info I will try to update Bios
@cherylhoward did you fix it and how to turn it that 20 times to try my pc will turn olny after 3hours of attemps or less or more
So, you are saying that you just kept trying to boot the laptop, and out of the blue, it successfully booted? That's not very believable because the fault would be there no matter how many attempts are made. It's not working for me.
Thanks Tom, I have exactly the same symptoms -- usually clicking, but with the very occasional random successful boot. One early "tell" is that if it will be a good boot, the screen backlight comes on, but if it will fail, the screen stays completely dead.
Anyway, I'm running Ubuntu, so the BIOS update is not the common path, and I'm still trying to figure it out. It's tied into UEFI somehow.
Edit: I have an Inspiron 17R-5737.
I have the same clicking problem, and the machine was booting occasionally, but now it just clicks and will not boot, so I can't install the flash.
@cheryl howard did you fix it and how to turn it that 20 times to try my pc will turn olny after 3hours of attemps or less or more
Tom Stephenson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 465
