The computer won't turn on
The computer won't turn on but the fn light stays on , when I press and hold the power button the cap lock, mute and mic off buttons light up and all go off then the fn light comes back on. Pressing the other buttons does not do anything
idk maybe the bios are corrupted i have the same probleme
Hi @fynn57407
If you have a Lenovo L13 laptop, try a full power refresh in case the BIOS has been corrupted for whatever reason and check if that resolves the problem.
Disconnect the charger (if connected)
Open the laptop, disconnect the main battery cable from the motherboard and then disconnect and remove coin cell RTC battery from the motherboard.
Here's the hardware maintenance manual for the laptop that will help. Go to the bottom of p.68 (74 of 111 pdf) and p.72 (78 of 111 pdf) of the manual, to view the procedure to disconnect the main battery cable and to remove the RTC coin cell battery, respectively. You don't have to remove the main battery, just disconnect it
Note: Once the RTC coin cell battery is out, measure its voltage. If it is <2.5V DC or if the battery is >4-5 years old, replace it. If it needs replacing, search online for 5B10S73571 to find battery suppliers that suit you best.
Press and hold the laptop's power button for a full 30 seconds and then release it.
Reconnect and reinsert the RTC coin cell battery on the motherboard, reconnect the main battery cable, reassemble the laptop, reconnect the charger and check if it turns on OK etc.
If it does there may be a message stating that the date and time are incorrect. This is normal as the BIOS has been reset back to its factory default condition by the above procedure. Once the date and time have been corrected, the message won't appear the next time that the laptop is started. If there were any user definable BIOS settings changed by you to suit whatever operating requirements you needed, they will have to be changed back again also.
Phantom crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2959996:0crwdne2959996:0 323
