The Nintendo Switch is a handheld game console that can be played on the TV via a docking station, or on the go. Released March 3rd, 2017.
The Swtich won't connect to the tv?
Dear all,
I do have a switch that wont display anything on any TV when dock.
So far, I have done the following
1- Used 5 different docks and confirmed that they do display to the TV using a different switch.
2- I have changed the type C port and still won't connect to the tv.
3- I have used multiple HDMI cable, different TV port and whole different TV, still wont display.
4- Followed all type of "fixes" on Nintendo website.
When docked, it will show the green LED and will charge the switch.
Does anyone know if there an IC/Chip that is responsive for this job and if it possible to even fix this isssue.
Thanks
it could be a bad filter near p13usb or p13usb itself
If you've run down all the other things mentioned on the Nintendo Switch No Video Out troubleshooting page (it sounds like you have), it's definitely possible this is a board issue.
The P13USB chip on the board is responsible for video output signals to the USB port. It is not uncommon for it to need replacement, or any of the data chokes on data lines coming from the chip could be bad.
If you want to jump down into the rabbit hole, you can find diode mode measurements for Nintendo Switch, including normal values for all the pins on this IC as well as the charge port. Just scroll all the way to the bottom of the linked page. (Images are not mine otherwise I would stick them right in the post). But you will need a multimeter with a diode mode function, test leads with small enough points to isolate the individual lines and some magnification will help loads.
zoko crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 4
crwdns2942667:0crwdne2942667:0 298
