Originally known as Beats Studio Wireless, but often referred to as Beats Studio 2 Wireless. Released in 2013 along with the wired 2nd-generation Beats Studio as lighter, stronger, and more comfortable. Successors to the original Beats Studio.
Headphones won't charge nor turn on - battery already replaced
Hi all,
I bought used Headphones and fixed them myself. Now after 3 years of usage without problems, my beats began to act weird. Some weeks ago when I wanted to use them, they went out of power. Discharging itself while turned off. So I charged it and it works for some hours. Some days later again, empty without using them. Since last week no sign of life. I bought a new battery, replaced the old one, plugged the charging usb cable but no charge indicator. I tried the 2 min's reset button combo 3 times, but nothing happened.
I checked all power sources and cables. Everything else charges fine, but not my beats...
I checked all solderings and cables but they are fine too. Is maybe my motherboard dead?
I also checked the USB Port on the beats. No sign of damage, or wobbly cable. Cable sits nice and tight.
Usually a new battery is not completely empty. It should turn on right after plugging the battery, but nothing.. any idea?
Hi
It sounds like you have a bad main board unfortunately
If you really wanted you could try and fault find the bad component with a Multimetre to you could replace the main board
Here’s a guide for getting the board out
https://www.youtube.com/watch?v=NRnIeZqk...
If replacing this board doesn’t help it could be a issue with the Bluetooth board
Heres a guide for that too
https://www.youtube.com/watch?v=YSLjEneZ...
Hopefully this helps
Any questions please ask
Ifixstuff crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 288
