At the end battery was replaced and working.
Thx to @dadibrokeit for the battery idea!
At the end I went with eBay and this model
https://www.ebay.com/itm/194981985707
3.7V 501646 LiPo 500mAh: 5 mm thick, 16 mm wide, 46 mm long
The original was 701547 490mAh: 7 mm thick, 15 mm wide, 47 mm long
Which means the second one has improved technology, because it is smaller and have slighter better capacity (500 vs. 490mAh).
So here we go:
(I am not able to upload the all photos I will try below latter. I have put Figure 1 and 2 which are the most important)
1. Cut out the old battery. Keep of the metal strips 1 mm approximately, that will be very useful to weld new wires.
2. Remove the Philips screw that keeps attached the circuit to the plastic case.
3. Weld the wires of new battery to circuit board (Figure 1). Don’t forget to put before heat shrink into the wires before (2 mm in each wire).
4. In Figure 2 the result after welding and heating the heat shrink.
5. Screw again the circuit to the case and put a plastic protector on the electrodes (just in case), thought the new battery comes with nice isolation (Figure 3).
6. Remove some plastic edges inside the top plastic case, because it will be easier to fit the wires and all the stuff, when closing (Figure 4).
7. Take care when manipulating the top case with the spring mechanisms: it is very tiny and if it get out, as happened to me, it is a little pain to put in place again.
8. Put everything together both cases and close it. Maybe you have to proper fit the wires in and make a little pressure, but the 4 tiny Torx screws will keep everything close.
Done. Now the glasses power on properly and with good capacity and…
Nice blocking screen, telling you to active in Recon website appears! This company I thing is out of business from some years ago, but that will be another puzzle to solve I’m afraid.
The glasses were not expensive in eBay, but if anyone knows have to activate them, I will appreciate so much!
Thanks for reading.
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
I was able to repair the battery with the help of Jerry W @dadibrokeit
See my own response below.
Thx
crwdns2934271:0crwdnd2934271:0 F There crwdne2934271:0
