The Bajaj Discover is a motorcycle brand by Bajaj Auto. Currently there are four variants of Discover- Discover 100 DTS-Si,Discover 125 DTS-i,Discover 125ST and Discover 150 DTS-i.
It can't start
My motor bike is not starting
crwdns2889612:0crwdne2889612:0 10
crwdns2944067:08crwdne2944067:0
Geoffrey Ouko what exact model is your motor bike? What have you checked? Do you have fuel? Do you have spark? Did anything happen to it or did this just start all of a sudden?
My motor cycle not start
Bettry charging
Palag problem
Indicetar chlu
البوجية لا تعطي كهرباء قوي
Translation Arabic - English
The spark plug does not give off strong electricity
@fgr31679 What make and model bike? What engine size? What year? What have you checked?
Translation
@fgr31679 ما نوع الدراجة وموديلها؟ ما حجم المحرك؟ ما العام؟ ماذا فحصت؟
If your Bajaj Discover motorcycle is not starting, here are a few things you can check:
  1. Check the battery: Make sure the battery is fully charged and that all connections are clean and tight. If the battery is old or weak, it may need to be replaced.
  2. Check the fuel: Make sure there is enough fuel in the tank and that the fuel valve is turned on. If the fuel is old or contaminated, it may need to be drained and replaced.
  3. Check the spark plug: Make sure the spark plug is clean and properly gapped. If it is fouled or damaged, it may need to be replaced.
  4. Check the air filter: Make sure the air filter is clean and not clogged. A dirty air filter can restrict airflow to the engine and cause starting problems.
  5. Check the carburetor: Make sure the carburetor is clean and functioning properly. If it is dirty or clogged, it may need to be cleaned or rebuilt.
  6. Check the ignition system: Make sure the ignition system is working properly. This includes checking the ignition coil, CDI unit, and other components.
If you are not comfortable performing these checks yourself, it may be best to take your motorcycle to a professional mechanic for diagnosis and repair.
Try kick start maybe your battery is worn out
Find your spark plug location. It's may be right and left side of the engine's nearby top side. Their have an adaptor to connect spark plug and that wire. Remove adaptor and directly keep the wire near by engine and kick the vehicle to start. It may cause to electrical shock. So do it carefully. And check any spark is present or not....
Bajaj platina
Chainset change
@diljeetkhan is your question on how to change the drive change and sprockets on a Bajaj Platina?
Geoffrey Ouko crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 109
crwdns2942667:0crwdne2942667:0 4,616
