Repair information and guides for the iPhone 8 that was released on September 22, 2017. Model: A1863, A1905
Broken rear camera glass & possibly damaged camera
Hi, the rear camera glass (or outer lens I guess) of my iPhone 8 broke when it fell. Now the camera is very blurry and reacts sluggishly and sometimes not at all. Can this maybe be solved by replacing the camera glass/lens, or should I get a new rear camera right away?
Hello Sarah,
if you can take an iPhone 8 apart, it shouldn't be a problem. If not, use the instructions in iFixIt or find a good repair shop. If you do it yourself, of course you will save money :-)
remove the screen and remove the main (rear) camera. You now have clean access to the broken lens glass. Clean the edge of broken glass crumbs and dirt. Reinsert the camera and check operation. You can clean the camera mechanism with compressed air or a brush (avoid contact with the lens from the front), this will unlock the magnetic mechanism if blocked. If there is no improvement, replace the main camera. The lens glass can be purchased and pasted into the housing, it will not be a problem. Remember that the camera must not be exposed to dust. Dust kills the magnetic lens stabilizer. Keep the camera removed from the housing in a plastic bag (it's antistatic inside)
that's all, quick work, quick money saved.
Hello Bert,
Great, thank you so much for the detailed answer and sorry for the late reply. I‘ll try fixing the glass first and see what happens.
sarah crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 1
crwdns2942667:0crwdne2942667:0 208
