there is sound but the screen is black.
Hi I have a Blaupunkt tv the blue solid light is on and there is sound but the screen is black.
Naeem Raja first you want to verify that you have no image on all inputs. So check all of the different input sources. If it remains dark, unplug it and push the power button for about one minute, then plug it back in. See if that resets your TV.
If it remains dark, use a flashlight and angle it against the screen with the TV at a station where you can hear the sound. See if you can make out shadows or shapes. If you do, then it is your backlight that has failed. If you do not see anything, unplug your set and remove the back. then visually check the boards for any obvious damage like burned or missing components, domed or leaking capacitors etc. Check all the wiring and unplug the wires and plug them back in to make sure they are properly seated. Post some images of all of your boards with your question. Use this guide Adding images to an existing question for that so we can see what you see. It is possible that this is either a power board issue or a T-con board issue.
crwdns2942667:0crwdne2942667:0 13
Naeem Raja what exact model is your Blaupunkt?
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
