Repair guides and support for USB flash drives, also known as jump drives, USB sticks or thumb drives.
I can't access into USB Pendrive..
Hi i need your help right now very urgent. my USB Pendrive not recognized or detected on THIS PC in my laptop/PC. I can't access into USB Pendrive..
Already try in Disk Management also not appear the Drive Letter for USB Pendrive. Inside my Pendrive a lot of important data/files.
How i can solve this problem..plsss help me..or you can email me Thanks You
Hi Syafizam,
First of all you posted this as an Answer when it is a Question.
Please clarify.
You say "Disk Management also not appear the Drive Letter ."
Do you mean it appears BUT doesn't have a drive letter or nothing whatsoever appears.
What are the specifications of the pen drive?
Make, model number, capacity, etc.?
Please clarify.
You say "Disk Management also not appear the Drive Letter ." # nothing appear any drive letter at disk mgnt...
Do you mean it appears BUT doesn't have a drive letter or nothing whatsoever appears. # attach usb to laptop its appear dirve letter few sec..only then none appear after that.
What are the specifications of the pen drive? # USB Pendrive
Make, model number, capacity, etc.? # HP 8GB
Hi,
Does this happen on all the USB ports in the PC?
Have you proved that there is power on the USB port by plugging in a USB mouse or a phone and check if the mouse's laser light turns on or if the phone indicates that it is charging?
If there is no power on the USB ports the pendrive won't work.
Go to Device Manager - Universal serial bus controllers - click on > to expand the list - right click on USB Root Hub - Properties - Power Management and uncheck "Allow the computer to turn off this device to save power" - OK.
Do this for all the Root Hub entries shown.
Then restart the laptop in the normal manner and check if the pendrive is now detected.
To get to Device Manager in Win10, press the Win key and the x key (both together) and click on the Device Manager link that shows in the options menu.
Here's an image that shows what it looks like. It is from my desktop PC but the USB Root Hub Power Management settings are the same for Windows OS.
(click on image)
Sounds like a board issue rather than a PC issue. If you can open the drive and check the solder joints on the board at the connector. These can dry out and crack over time. Also check for bad components, caps etc.
YouTube North Northridge fix. He has a few videos on usb drive repair.
Syafizam Shafii crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 153
