The LG V60 ThinQ 5G, commonly referred to as the LG V60, is an Android phablet manufactured by LG Electronics as part of the LG V series. It was announced in February 2020 and is the successor to the LG V50 ThinQ. On April 5, 2021 LG announced it will be shutting down its mobile phone division and ceasing production of all remaining devices. LG noted the phone will be available until existing inventory runs out.
My charging port isn't working
Ever time I put in the charger in the charging port I do not get a charging signal
Hi,
Have you tried a different known working compatible charger or USB-C cable to prove that the problem is in the charge port, you didn't say?
Visually inspect the charge port using a strong light and a magnifying glass to check that there is no lint etc in the port that may be preventing a good electrical connection. If the port is blocked with lint, debris etc, do not use a pin or probe to get it out as you may damage the pins. Try using either canned air or maybe a vacuum cleaner to see if this removes it.
If it is the charge port then most probably it will have to be replaced. Search on YouTube for how to replace the charge port in your model phone.
Easy enough to fit.
OK, that's great. So, where can I buy one that doesn't cost six hundred dollars, LOL. One that isn't a cheap Amazon imitation that will fail to work. I am in Canada and American sellers cost me at least a third more, plus customs, so if you could at least point me to what the real thing is, I can find one from there. Thanks.
SicEric Tech’s YouTube channel has a 2-video walkthrough of how to replace this part. Overall it is good, but I noticed too late that one of the first batch of Phillips screws was brassy and about two hairs shorter than the rest. Wish me luck, because the odds of getting it back into the right hole are now quite slim…
A mí me pasó lo mismo con el puerto de carga de mi LG v60, un año batallando. Lo que hice fue echarle aceite wd-40 y se arreglo, pensé que era coincidencia y lo hice con el celular de mi hijo, (tiene uno igual) y también se arregló el problema. El mío no detectaba el cable y el de mi hijo hacia falso contacto, a pesar de que no se manipulara durante la carga.
Yo lo hice durante un día completo, tratar de mantener el puerto "impregnado" del líquido (wd-40) y sí, hasta ahorita no me a fallado. De hecho lo conecte aún con restos de líquido, ya que no es conductor de electricidad.
San Google dice... "WD-40 no es conductor de electricidad y elimina rápidamente corto circuitos provocados por humedad en equipos eléctricos y electrónicos"
In case you still have the phone there is two things that could be happening based on my own experience:
  1. The charging port is giving up, this is a known issue on the LG V60 due to the way the charging assembly was made, as it is on a flex cable replacements are (or used to be) dime a dozen, so just look on ebay or amazon for a replacement one.
  2. Or the charger is not supplying enough amps, for some reason when I try to charge mine with less than 5 amps it will not send a charging signal, try using a 30-60 watts brick and a 5 amp compatible charger, UGREEN has some, and see if it works.
Thx. It turned out to be the port. I did the easiest cheap fix and dissembled it, replaced the board with the port on it, and reassembled. Probably need to buy a heat gun with lower settings than what I had already if I want a better seal. Also have my fingers crossed that I put the ever-so-slightly longer screw back in the right hole,.since the guy in the youtube video I followed along with didn't notice it and my arrangement got jostled.
Well I think the charging port on your phone might get damage I will suggest you to replace the charging port with the new one.
The Legend Ngwenya crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 21
crwdns2936753:030crwdne2936753:0 69
crwdns2942667:0crwdne2942667:0 4,209
