Power up and shuts off on it's own
I power my tv on (Sanyo DP50747 Plasma) and the picture acts like it wants to come on, then shuts off within 10 seconds. I power it up again and the screen shows a little more. When I do it a third time it acts like it is warmed up and works fine after that. I took the back off and looked at the fuses however they have a white film over them. How do I fix this? It has to be something simple.
I have a Sanyo flat screen and I power it on and it takes like 5 to 10 seconds and then shuts itself off second time I turn it on it comes on for like 5 Seconds and then the third time I turn it on comes on shuts off and won't power back on any help
Thanks
I recently had this issue and was able to find the same tv with a damaged screen that I could use for parts. After swapping the power boards. I still experienced the same issue. I then unplugged the board that controls the power button on the side of the tv and the problem went away. I then swapped the boards from the spare tv and all is working fine.
Chris, check your power board and see if your caps are either leaking (sticky oil like substance on the PCB) or if the tops are bulging. Those are the once to replace. Parts are available at places like this if you want to replace the board. Your caps can be purchased inexpensively at places like Mouser.com and Digikey.com Of course, make sure that you read and follow the safety precaution when and if you decide to work on your TV.
I had the same problem with mine. It eventually got to the point it took 10-15 minutes of off and on to start up and now it won't start up at all.
When you turn it on it turns itself right back off in seconds.
I'm thinking it may be the power board. I've got the back off and looking at it and believe I can RR but not sure it's worth the price of a new power board. :(
Don't buy another sanyo, built to last 2 years and then this happened to mine also, turns out to be common problem they know about, new board won't fix it
Sanyo 55 tv
FW55D25
Turns on then turns off 10 secs later.
I replace the power board,main board. And still doing the same.
Caps are ok. I don't see nothing wrong with the components.
Can some body help me to get this tv. Fix.
Thanks.
I'm frustrated just as you my television does the same darn thing it's ridiculous! Do you know I have two televisions that do that in my house! I have moved to another place and they both still do it! One is and insignia TV purchased on Amazon few years ago it's a smart television. The other one is a sanyo Smart TV does the same exact thing!
Mine won't even turn on spark flash nothing. Piece of $@$*
Chris crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 6
crwdns2942667:0crwdne2942667:0 24,366
