In June 2017 Apple updated its 13" MacBook Air with a newer Broadwell Intel Core i5 processor, resulting in slightly increased performance and battery life.
Spacebar Wasn't Working: Then I dislodged this rubber nipple
My spacebar was sticking and not really working on my Macbook Air. Like an idiot, I slid a piece of a stickynote under there to see if I could clean out the dust. In doing so, amazingly, I managed to dislodge this little rubber nipple. It just slid right to the side of the key and then almost out from under the key. Since it was clearly already dislodged, I just pulled it the rest of the way out. They spacebar key itself is still in place, but now it stays down and won't raise back up. I assume raising it back up was the purpose of this little rubber piece.
I'm trying to avoid a $500 full keyboard repair. The little rubber piece is still intact and undamaged. Anyway I can fix this myself?
Hi
Iv seen this happen before on its own
And there’s a fairly easy fix that I have found to work
If you get loctite superglue (gel) and carefully apply it along the bottom of the silicon button that fell off(not too much) and sit it where it originally went ,then leave it to set for the recommended time it should work fine again
If you tell me what region you are from (UK,USA,EU…) I can get you the correct link
Hopefully this helps
Any questions please ask
Hello! Thank you so much for the answer and help. I am from the USA, a Link would be so helpful! Do you know of any good guides on how to get the spacebar off? I assume I'll have to remove it to put this little piece of rubber back in place. Right now, the spacebar is still securely on, it just won't raise up. Again, thank you so much!
@Molly Rockett
Hi
Sorry for the delayed reply!
Here’s a USA link to the superglue
https://www.amazon.com/Loctite-Control-4...
And here’s a video on how to get the space bar off
https://m.youtube.com/watch?v=R-O06r6-pq...
If you have any trouble getting the space bar up let me know and il help:-)
Amazing, I seriously can't thank you enough! I am ordering the glue and will try this ASAP.
@Molly Rockett
That’s great!
Let me know if there’s anything else:-)
A suggestion is not to use super glue since its so harsh and a pain to remove if you mess up. My recommendation is to follow @hellomacos guide but use a silicone glue instead. Its the closest to factory glue used. If you mess up you can just apply a bit of pressure and it will come off. Mines worked for the past 2 years. Gear Aid silicone works great https://a.co/d/ir032o5
Molly Rockett crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 28
crwdns2942667:0crwdne2942667:0 747
