Google's third-generation Pixel-branded smartphone, and their first "notched" phone. Comes with a 6.3" QHD+ OLED display and 64 or 128 GB of storage. Available in Nearly White, Just Black, or Not Pink.
Why won't the power button turn my Pixel 3 XL on?
Power button works to turn the phone off, but if the phone is already in the off state, the power button won't work unless phone is plugged in. This is the case even when the phone has a full charge. Wondering if this is a faulty button, or if the problem will fix itself when I install the new battery I already have on order. Thanks!
Thanks! I didn't know about the partial charge extending the lifespan. I'll give it a shot. Regarding the power button issue, I'll post again once the new unit is in. So stoked on these genuine Google parts!
If it works when it's plugged in, the most logical explanation would be a battery issue. Perhaps the voltage drops too low when unplugged because the battery is too old.
For future, I recommend limiting charging to less than 100%. Even charging to 95% gives your battery about 150% longevity. It goes like this:
100% - 1x longevity
95% - 1.5x
90% - 2x
80% - 3x
The best way to do it is by rooting your phone and installing the app Battery Charge Limit. An easier way is using the app AccuBattery to alert you when it's time to unplug the charger. But with the root app, it turns off charging on its own and reportedly works with Samsung, Pixel and Nexus phones, and many more (using it personally on the Nexus 5X).
I've replaced my batter and it charged successfully, however the phone will not power on. When plugged in the screen indicates 100% charge so there doesn't appear to be a screen issue.
Did you manage to fix the issue?
Daniel Iwama crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 421
