Can't remove chuck from drill
I have the ryobi p214 cordless drill and no matter what I cant remove the chuck. I took the screw out from inside the jaws and I put an allen wrench in and held it with the jaws. I managed to turn the chuck counter clockwise but it just barely spins without loosening at all. How can I get the chuck off?
crwdns2944067:05crwdne2944067:0
@archiep once you got the allen wrench locked, you placed your drill in REVERSE (lowest torques setting)and you do have a full battery? Now pull the trigger. Careful, It'll kick a bit and you got to hang on to it and watch your wrist.
crwdns2934271:0crwdnd2934271:0 oldturkey03 crwdne2934271:0
I did this, but the drill started smoking and it also kept auto braking unfortunately.
crwdns2934271:0crwdnd2934271:0 Archiep crwdne2934271:0
I have the same problem? I cant tighten the chuck enough to stop the drill bit just spinning in the chuck , so , I want to fit a new one but cant remove the old one? Cant see any screw / bolt up inside the chuck at all? Hopeless system?
crwdns2934271:0crwdnd2934271:0 James McDonaldsonavitch crwdne2934271:0
Had the same problem so dismantled the drill down to the point where I had just the shaft with 2 flats on the end, clamped it in the vice , 10mm hex key in the chuck and heated the hell out of the old chuck, it let go with a bang and the thread is not a 1/2" 20 thread as mentioned, still to indentify, be careful during disassembly as a lot of small gears and parts, photograph each stage.
crwdns2934271:0crwdnd2934271:0 Alan Weaver crwdne2934271:0
Also good to note that the screw is a reverse thread
crwdns2934271:0crwdnd2934271:0 Robert Grayson crwdne2934271:0
