Released in 2017, the Dell Inspiron 15 Gaming 7577 is a gaming-oriented laptop with a 15-inch screen. It has a 7th-generation Intel Core processor and an Nvidia graphics chip inside.
Some Buttons don't always work.
On my keyboard there are some buttons that don't work properly. Sometimes they work and sometimes they don't.
crwdns2944067:04crwdne2944067:0
Hi,
Are they always the same ones or different ones every time?
Have any liquids be spilled on the keyboard at all?
Did you clean it?
Yes it always the same and no there's no liquid got into it
I don't know how to clean my keyboard from inside
I would try cleaning underneath your key caps and see if you can get your keyboard to function afterwords. The best way to do this is to remove the key caps from the keyboard itself. There is a guide on how to do this that I will link here.
I would also check to see if the ribbon cable that connects the keyboard to the logic board is seated correctly and is not damaged (I.e. any creases in the cable). If none of that works, it could be that the switches for the keys are damaged in some way, which means you would need to replace the keyboard.
Definitely try to clean the board first, and make sure that the cable is good first before looking for the replacement.
Thanks for your reply I will try this now
emad ayad crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 635
