The Lenovo YOGA 730-15IKB is a 15" foldable laptop with dedicated graphics and a high-resolution touchscreen. Released in early 2018. Model number 81CU0009US.
crwdns2934591:010crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Lenovo doesn't go to sleep when lid is closed.
I recently changed the the back cover of my screen because it was worn out, and since then, my laptop doesn’t go to sleep when I close the lid. I assume that I lost the lid cover magnets/sensors. Is that correct?
If so; Is there any way I can buy these magnets/sensors?
Thanks, Jorge
Hi @jorsouto ,
Have you checked if the original lid still has a magnet installed that you could use? Perhaps it is supposed to be integrated in the lid all the time and the replacement didn’t have one. Just a thought as I don’t know if this is correct or not
Have you verified that it is a missing/moved/loose magnet that is the problem?
Check the lid switch settings to make sure that they’re OK.
Slowly run a magnet around the top outside edge of the keyboard/upper case assembly and check if the switch operates and places the laptop into sleep mode or at least turns off the display.
Here is an image of what the magnetic switch looks like, along with its designation (UHST) on the systemboard. So if you locate the switch by using the magnet around the upper case assembly, the lid magnet should be in a corresponding location in the lid. If you can’t find it using a magnet you may have to open the laptop and find the switch.
(click on image to enlarge).
Here’s the hardware maintenance manual for the laptop, that may also help with the dis-assembly as well
Just some things that I’d try
Am also facing this in multiple laptops ... mostly after installing latest windows updates or lenovo vantage causing this issue...
this is not hardware issue...
can someone fix this
Hi @onedollars52860
Have you checked that all the "lid switch settings" as shown in the link in the answer above are what you want?
thank you so mutch it really help as the new chassis doesn't have the magnet in it , so i took it from original one and now its perfectly working .
Jorge M Souto crwdns2934231:0crwdne2934231:0
crwdns2936753:07crwdne2936753:0 29
crwdns2936753:030crwdne2936753:0 96
crwdns2942667:0crwdne2942667:0 6,016
