Device repair and troubleshooting for the 7" RCA tablet released in 2014, identified by model number RCT6773W22.
Why is my tablet stops inbetween while I'm using
While I use my tablet the screen turns off automatically and the screen blinks and it shuts down automatically and restarts again….after I use it for a while again it does the same manner
Hi,
Does it do this only when using the same app or different apps?
Does it do this with the charger connected?
When I try to use itself it automatically turns off....like 3-5 minutes it stays on I use a little bit and then it turns off automatically and restarts again and again I can't able to use it properly at all
If I enter any application it tells sorry it's not working....
@Philip Judson
Try starting and using the tablet in safe mode and check if it works OK.
If it does then a downloaded app is the cause of the problem.
The trick is to find out which one. A downloaded app is one that you downloaded and installed and didn’t come already installed with the tablet
To boot into Safe Mode, first hold down the power button until the boot menu appears. Then, hold down the "Restart" option until a window appears that confirms if you would like to boot into Safe Mode. Select "yes" or "ok", and allow the tablet to restart.
I tried to brother but it's not working the safe mode nor the restart button doesn't come on screen brother I tried to factory reset also but it's not working brother
@Philip Judson
I don't know.
If you can't get into the Recovery menus to do a hard reset then I don't know how you could reload the firmware
Philip Judson crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 127
