A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
Black Screen, Backlight works, HDMI works
Hey y‘all ?
I could buy a used Macbook Pro 2016 13" with touchbar for a good price. The problem is that the screen stays black after starting it. Backlight seems to work and using it with a HDMI also works. Using a flashlight also does not seem to show anything (makes sense if backlight works though). What do you think it could be? Is it worth buying it and trying to fix it? I don‘t have the macbook yet, so can‘t run any tests.
Thank you very much for your help! Yours sincerely. Michael
This system has a bad T-CON board which is part of the internal display assembly. You’ll need to replace the full display assembly to fix this.
Here’s the needed part MacBook Pro 13" Retina (Late 2016-2017) Display Assembly and here’s guide MacBook Pro 13" Touch Bar Late 2016 Display Assembly Replacement
crwdns2886500:0Replace a display compatible with a 2016 or 2017 model A1706 or A1708 MacBook Pro 13" Retina laptop. Includes the 2560 x 1600 13.3" Retina LCD Screen, Display Cover, Bezel, FaceTime HD Camera, Clutch Hinges, Display Daughter Board, Cable Spring Mechanism. Part #661-05096.crwdne2886500:0
crwdns2934075:0crwdne2934075:0
$444.99
michaelmoser123 crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 102
