If you remember where the majority of the spill went would be helpful in knowing how far you’ll need to go.
Reference this guide MacBook Pro 13" Two Thunderbolt Ports 2020 Display Assembly Replacement jump down to Step 21 we’re not taking the system fully apart here just gaining access to the hinges. The coils you see are a clutch mechanism using some cotton swabs (Q-Tips) wipe them down slightly damp with distilled water to remove the sugars from your spilled soda. Be careful! You don’t want the wet to travel into your system! Use a can of can’ed air to blow any moisture away (into the corners).
Then get some WD40 spray into the cap to concentrate the spray >> Do not spray into your system directly!! << Now dampen a clean cotton Swab with the WD40 in the cap and wipe the coils (it doesn’t take much!) see if that solves the problem.
The next direction is the ribbon cables. Here we do need to follow all of the steps to Step 29 in that image you can see the two retraction springs and their belts which help rollup the ribbon cables.
Using the same method we applied on the hinge clutch mechanism we need to wipe the coils in the same way and in addition the strap which rides along the ribbon cables will also need to be wiped down with distilled water making sure all of the sugars are removed. but instead of WD40 we need clean talcum powder (no perfume or dyes) again its not quantity its an ultra thin coating to prevent the chaffing of the two surfaces.
This is what will be needed are you up to the task? Any mis-step can make a bigger mess! Maybe you should locate an independent shop who has the skills to do this (this time paying).
I would leave the TouchID button alone! If you mess up that’s the end!
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
0
crwdns2944067:08crwdne2944067:0
To start with the 2010 13" model doesn't have a TouchID so we are clearly talking about a different system!
So when did you buy the system and are you sure its a 13" not a 15"?
We really need to correctly ID your system before we can aim you to what's needed.
Think of it this way you have a VW beetle and I aim you to a Chevy 4x4 engine overhaul not very useful is it!
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
It's a macbook pro 2020.
crwdns2934271:0crwdnd2934271:0 Shannon Santa crwdne2934271:0
@santasbaby2020 - Getting warmer! 13" or 15"
And how many Thunderbolt/USB-C ports 2 or 4?
MacBook Pro (13-inch, 2020, Two Thunderbolt 3 ports)
@santasbaby2020 - Great! Now we have a firm idea which system.
