The Canon PowerShot is a 5.0 megapixel camera with 4x opitical zoom.
Why won't the camera power on?
The camera won't power on. I put in new batteries and still no power.
Judi, make sure that the contacts on your camera are actually making solid contact with the battery contacts. Also make sure that there is no corrosion or debris on the contact. Clean them with some isopropyl alcohol or a mild backing soda solution. If you battery is okay and if the contacts are clean and in touch with the battery,you may have to dig deeper and dismantle your camera. There are two fuses on the PCB that you could check for continuity. Also, make sure that the connectors and wires coming of the battery box are properly seated. Hope this helps to get you started. Good Luck.
That’s amazing! I ran into the same problem but missed your reply. However, with Gemini's guidance, I also discovered that it was a fuse issue.
Judi crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 1,314
