hi @walterwhite4773
Try the following
- Run the computer in safe mode
- Hold down the Shift button and then press and hold down the POWER button until the computer restarts.
- Recovery Mode
- Press and hold COMMAND + OPTION + P + R and then press the power button
- Reset SMC
- Press and hold SHIFT + CONTROL + OPTION then press and hold the the POWER button for 10 seconds
- Then Press power button to turn on the laptop
If these method fail, then remove the back cover of the laptop and disconnect, the battery, keyboard and trackpad connectors, SSD (if installed) and the display connector (OPTIONAL) for about 30s to allow the system to drain the remaining charge. Re-connect everything and try to turn on again.
If this still doesn’t bring back your image, I would be looking around the display connector to see if there is any obvious signs of damage or dislocation of the connector itself.
Hope it helps!
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
