New Track pad installed over and over and can't get to work properly.
Hello, I recently wanted to perform a handful of upgrades on my old 2012 13” MacBook pro and came across this great site. I decided to swap out to a SSD, upgrade to max ram, new battery, and swap out the track pad. Everything has gone great so far with the exception of the track pad. It’s been giving me issues and i’m not finding a clear cut fix online.
I swapped it out just as described in the tutorial here and had very little mouse movement once I powered on and rebooted. I found that I may need to loosen the center screw towards the bottom, that didn’t seem to work. still very little spare movement with seemingly random clicking throughout. Is it possible I have received a bad piece of hardware? Before I install the old track pad back I figured I’d see if anyone has any tactics to fix this one.
Thanks!
Update (04/13/2021)
I continued to try to adjust the new track pad to get it to function with no success. I can only get very slight movement with the mouse here and there, and clicking or right clicking or any of the functions that the track pad can perform don’t seem to be working at all. I replaced the new with the old one that was in there (because I was only replacing because it was the original and I was opening the machine so figured why not) and it works perfectly as intended.
Hoping with this new information theres someone out there that can help me narrow down the issue.
Thanks again
So your issue is the trackpad is not able to track your finger as you slide it across left to right or up and down across the full surface the pad as well as the other direction is that correct?
Or is your issue only when you depress the lower edge (click function)?
These two issues require different corrections.
crwdns2934271:0crwdnd2934271:0 Dan crwdne2934271:0
@danj Thanks for the response. The issue is all of the above. Not detecting finger movement as well as not no clicking function. The pad is loose enough to where it does depress slightly and can hear it but it doesn't do anything. Occasionally I can get the pointer to move very sparsely.
crwdns2934271:0crwdnd2934271:0 Igor crwdne2934271:0
