Hi @imbob218 ,
Check that the dishwasher’s hot water supply is 120 deg. F (49 deg. C) at the dishwasher. (see p.6 of the installation manual)
The heater element only raises the temperature by some 40 deg. F maximum (see p.16 of the user manual for the different temperatures used by the different wash cycles).
If the supply is not hot enough then the heater may not be able to bring it up to the required temperature.
Hi @imbob218
According to this supplier the manufacturer’s part number for the tech sheet is Tech Sheet - W10849767 - Rev A.
Scroll down to p.5 and find the Water Heating/Heat Dry and Water Sensing with O.W.I. Sensor (Water/Air/Soil/Temperature) circuit.
On p.6-7 it shows how to get into the Diagnostics, what the error codes mean if any shown and what to look for, for each error code.
Hopefully between using the two you will find the problem
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
2
