Hi @akmonkey
Please verify the model number of the laptop just in case I’ve linked the incorrect part below.
No charging indication in a laptop usually means a problem with the charger or the DC-In jack (supplier example only)
Have you checked the charger's voltage output (19V DC) to see that it is OK?
If the charger’s output is OK, a lot of times the centre pin connector in the DC-In jack breaks internally and this opens the power circuit from the charger to the motherboard.
You would need to open the laptop and then disconnected the jack cable plug from the motherboard and use an Ohmmeter to test the wires from the jack to the plug for continuity
crwdns2934113:0crwdne2934113:0
crwdns2915270:0crwdne2915270:0
crwdns2889612:0crwdne2889612:0
