The late 2005 Power Mac G5 was introduced in October, and discontinued in August the next year. There were three configuration options, one dual core processor at 2.0 GHz, one dual core at 2.3 GHz with model number A1177, and one dual core dual processor (quad core) at 2.5 GHz.
crwdns2934591:026crwdne2934591:0 crwdns2934593:0crwdne2934593:0
Can't boot on hard drive or CD/DVD - grey/gray screen of death
A few weeks ago my PowerPC G5 Dual Processor Early 2005 running Leopard OS X froze while the screen saver was running. I hard-powered-off the computer --> held down power button for ~10 seconds. When I tried to start up again, I got the "gray/grey screen of death" with the Apple logo. The screen hung there and then fans starting ramping up to full speed with no sign off boot up. I know others have posted similar issues, but I wanted to start a new thread.
Basic Specs:
PowerPC G5 Dual 2.5 Hz (?) Processors
4 Gb memory (recently upgraded form 2 to 4) ***
Bought in early 2005 (I think)
Here's a summary of what I've tried:
DOES NOT WORK
- booting up holding down C (for drive) --> straight to kill screen
- booting up from original discs for G5 (from both C mode and Option mode)
- booting up from 10.5 Leopard disc (from both C mode and Option mode)
- booting up holding down Option-Comman-P-R --> straight to kill screen
DOES WORK
- connecting to secondary computer using target mode (holding down T) - I can see both of my hard drives
- booting up holding down Option - I can select either my main drive (secondary is not present there but there is no OS on it) or CD/DVD in slot
- booting from Apple Hardware Test (AHT) disk from Option menu
-- I ran disk checks, had errors. I ran Disk Warrior from secondary computer in target mode and repaired the drive, running the AHT test again shows no errors
- ran disk repair from secondary computer to fix errors (using disk utility and disc warrior)
OTHER THINGS I'VE DONE
- replaced backup battery on motherboard that was weak at only ~70 mV with fresher battery at ~3.6V
- held down PMU (not SMU) reset button for 30 seconds
- (main fans were cleaned a few weeks before issue)
- two weeks before issue I installed more memory (from 2 Gb to 4 Gb with two new 1 Gb cards)
- backed up data - so I can delete drives if needed
THOUGHTS
- I'm concerned that under CPU it shows 158950.77 GHz - shouldn't it be showing two CPU?
- the drives look healthy when looking at them in target mode
- issue is occurring between power up and drive selection (since CD/DVD is also not viewable)
- maybe the new memory caused local over heating to the motherboard?
- I may be able to replace the heat sink, but the spare computer I have access to has different looking hardware. It's probably a different model of the G5. My computer has one metal case cover and the extra one has a split case cover.
NEXT STEP
- I need to back up secondary drive fully first
- pull out new memory sticks
- pull out all memory except originals
- pull out secondary drive
LAST RESORT
- buy external case for drives and cry about how no one will buy my dead desktop
Because this is a long description, I will post updates in the comments and a final comment here:
(Coming Soon)
crwdns2942205:01crwdne2942205:0
FYI I've been trying a bunch of things from suggestions from the Apple Discussions Forum for those that might be interested. I will update this thread as well if any resolution is reached and I'm checking both locations.
URL: https://discussions.apple.com/message/16...
I would remove the new memory as a first step. If that fails considering all you've done I would begin to think about a CPU, logic board or power supply failure. Please don't do anything rash until we hear from mayer on this. Good luck.
Here is a link to the ebay G5 parts page
http://www.ebay.com/sch/i.html?_nkw=powe...
Thanks for the post. I'm backing up data on my second drive and then I'll play doctor on the computer. I don't think it's the power supply as the computer fires up every time. Although the logic board battery was drained, which may indicate some sort of extra load on the system (or that it's 6.6 years old!).
I removed the extra memory. No Change.
I tried Shift-start-up. No change.
So I have the log but it's a HUGE text output. I did see the words fatal error mentioned. Should I cut and past the whole thing here??
I'm going to remove some other memory modules to see if maybe they had an issue.
redacted crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 9
crwdns2942667:0crwdne2942667:0 4,612
