Upgrade storage with an ssd
Can I upgrade the available storage with an ssd?
Hi
It looks like your’s is the model that already has a HDD installed and perhaps you can add a SSD, as there is provision for a sata HDD and an M.2 SSD on the motherboard or if you can add the M.2 SSD then you can have 2 x SSD by replacing the HDD with a sata SSD and adding a M.2 SSD as well.
Here’s the maintenance and service guide for the laptop, taken from this webpage.
Go to p.62 to view the necessary pre-requisite steps and then the procedure to remove/replace the HDD.
Go to p.67 to view the necessary pre-requisite steps and then the procedure to remove/replace the M.2 SSD.
Here’s a link to a RAM and SSD supplier. It is only to show you what SSD (sata and M.2) are compatible with the laptop. There are other suppliers that may suit you better. You can also upgrade the ram to a maximum of 16GB (2 x 8GB) as well if you want to.
Hopefully this is of some help
crwdns2947821:0crwdne2947821:0
crwdns2947823:0crwdne2947823:0crwdns2936751:024crwdne2936751:0 0
crwdns2936753:030crwdne2936753:0 2
crwdns2942667:0crwdne2942667:0 961
Hi,
You should be able to but just to make certain, what is the full model number of the laptop?
crwdns2934271:0crwdnd2934271:0 jayeff crwdne2934271:0
I think it’s k203tx.
crwdns2934271:0crwdnd2934271:0 Prashanth T crwdne2934271:0
