iPhone 11 pro not included
Hello, the phone is obviously dropped and does not turn on. what is its problem circuit board or battery.
If you did have vibrate on mute enabled, you can perform a quick and easy test. Simply flip the mute switch. If it vibrates then its obviously not the battery because it is powered on. You could also try to call your number. If it rings then again, it’s powered on. If you dropped it you most likely damaged the OLED panel.
Thanks for the info will work. ;)
crwdns2942667:0crwdne2942667:0 261
have you tried a replacement screen at all?
crwdns2934271:0crwdnd2934271:0 Jade Richards crwdne2934271:0
I'm not I thought it was the battery
crwdns2934271:0crwdnd2934271:0 dimit1r89 crwdne2934271:0
