The wi-fi only version of Apple's iPad Air, model number A1474. Available in Space Gray or Silver, it packs the custom A7 processor and ships in 16, 32, 64, and 128 GB configurations.
crwdns2934591:0299crwdne2934591:0 crwdns2934593:0crwdne2934593:0
ipad air a1474 sleep lock button don't work,but turn on
hi dears
after change digitizer for ipad air 1rst model,all was fine when i test digitizer before installation.all work perfect.but after installation power button turn ipad on and off.but won’t sleep or wake ipadalso when ipad turn on its go to sleep directy after start.
i triedt lo lock ipad from home button accessibility,and its not work also from there.
hardware fix looking for if some expert here can help :)
Hello, you have a faulty sleep/wake sensor. This is a solder component on the digitizer itself. It can be replaced, but it is much easier to just replace the digitizer again with a high quality part. I have had this issue with cheaper vendors before.
hi dear
thanks for your answer, i wait to change the home button connector first and check again with new digitizer to see if its help.
will replay here when i get it done.
thanks so much
Lasse ANB crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 3
crwdns2942667:0crwdne2942667:0 53
