TX-55CX680B slight double vision/ghost screen.
Hi, what may be my problem? It’s not T-CON or Ribbon cables.
@mountpleasure not sure how you determined that it is NOT the T-con board. If you are absolutely sure about that, then the only other possibility is a bad panel. The LCD driver board most likely has some bad drivers.
Hi @oldturkey03 , thanks for your reply. I replaced both T-CON and Ribbon Cables, no difference
Darn that will most likely be a bad panel (driver board). Of course you can always try and change the main board just to be sure. Get it from a place that has a good return policy or an inexpensive used one.
crwdns2942667:0crwdne2942667:0 50
