Flagship smartphone from Huawei released April 2019. Featuring a 6.47" FHD+ OLED screen, in-display fingerprint sensor, 40 MP main camera plus 8 MP telephoto camera and a new earpiece speaker technology. Model VOG-L29 and VOG-L09.
crwdns2934591:048crwdne2934591:0 crwdns2934593:0crwdne2934593:0
phone can’t read sim ... I get NO SERVICE
Hi hello there guys …
I opened my phone back cover ….
for doing testpoint for fixing software thing …
I flashed a few firmware ( ROMS)
for test … in beginning everything was working…
in my last try phone was bricked …
so need to open back cover for testpoint…
it’s took me a week to work with phone till
can fix it to work again…
everything looks good…
but I have no network… no service…
phone doesn’t recognize the sim….
I tried to look if something is no connected…
but it’s all look ok….
I don’t know how? and where to check for fixing the problem??
what should I do?
please help
crwdns2944067:04crwdne2944067:0
same here can anyone here help me with my Huawei p30 pro it now not reading sim card
I have dual sim Huawei p30 pro and sim card works only In one slot.
I have this same problem I mean no service at all tryed so many sim cards no any worked. So I bought new replacement sim card board changed still not working .. any idea where is antenna or is build up In sim card board? I would buy antenna but can't find any on eBay etc can anyone help me please localizate problem Huawei p30 pro
Can someone make it work the sim card reader? I have the same problem with a Huawei p30 pro.
there is a video on u tube showing that sim card cable to motherboard is the fix
crwdns2942205:01crwdne2942205:0:
do you have a link to said video by chance?
I don’t know for certain how to fix this, but…standard troubleshooting procedure to help isolate the problem would be:
  1. Have you got the SIM card in the right way, and in snugly?
  2. Have you tried the same SIM card in a different known good phone
Hi hello there my friend
the answer is yes … for 1…
and yes for 2
I use this sim everyday … also tried other 3 SIM cards ….
still no service…
hope can find good advice… have a good day…
I have the same problem. I've tried antenna replacement, sim reader replacement, pcb flex replacement. I have not tried a new charging/ main board flex this is my next theory to try (waiting on part delivery). If main board flex does not fix my next theory is that the main flex connector on motherboard might be "loose", customer had damaged original screen in the same area as main board connector. Would need to resolder or replace and solder main board flex connector. If that is not successful I may have to replace band width ic chip. Note I've also tried going back to earlier software version, did not work on previous software versions.
Yuri crwdns2934231:0crwdne2934231:0
crwdns2942667:0crwdne2942667:0 3,424
