A50 won't charage or turn on - Overheating icon
I have an A50 that started claiming that it was overheating and wouldn’t charge. I tried:
Factory reset - No change
Clean charging port with pin, IPA, q-tip - No change
Remove rear cover - Minor water damage on some chips on charging daughterboard, and on the main board.
Replace midframe - No change
Shorting the 2 pins on the side of the motherboard that corresponds to the power button sometimes lets the phone turn on depending on what is connected.
Cleaned water damage with IPA and q-tip - No change
Removing these three PCB components resolved the problem for me. I used a soldering iron and managed to get them off in the end.
https://fixpirate.com/samsung-a20-a205-o... - This shows a very similar process for a very similar board from the Galaxy A20.
Buying a new charging port should also fix the problem properly.
I believe this solution may merely removes the phone’s capability of detecting the temperature, and as such, buying a new charging port is a recommended solution.
Remove them or replace them?
You just have to remove them.
I simply removed them, which removes the phone's capability to sense the temperature. I do not know if this is the root cause of the problem, so I don't know if replacing them will fix it properly.
I have the same issue. Removed the three components and now it turns on but wont take a charge. Any ideas? Might also be the battery as it has a dent in it but I don’t think that’s the case.
Joel Taylor crwdns2934231:0crwdne2934231:0
crwdns2936753:030crwdne2936753:0 74
crwdns2942667:0crwdne2942667:0 12,274
